Purge solenoid
2005 CHEVROLET EQUINOX
243,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
BAILEAB
I recently changed the purge solenoid on my vehicle, but the vehicle is now running worse. When i unhook the wire thing from the solenoid. is there supposed to be a change in the motor while running?
Feb 23, 2020 at 2:31 PM
Good afternoon,
No, there will not be a change at all.
Why did you change it? Was there a code for this component?
Is the check engine light on? If so, do you know the codes?
Please give me as much information as you can.
Feb 23, 2020 at 2:54 PM
BAILEAB
It's throwing a multiple cylinder misfires and check engine light is flashing when you go down the road. My husband changed it because he broke a piece off when changing the spark plugs and wires.
Feb 23, 2020 at 3:08 PM
Okay, thanks. that makes sense.
I would start by checking the fuel pressure. Low fuel pressure will cause misfires and make the engine run that way.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Feb 23, 2020 at 3:21 PM
BAILEAB
Okay, thank you.
Feb 23, 2020 at 4:23 PM
You are welcome.
Always glad to help.
Feb 23, 2020 at 4:38 PM
