pulling my my to the left
2007 NISSAN PATHFINDER
93,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
MATT07
why every time i press my brake its pull me to the left.i had my wheel alignment done.but still pulls my car to left
Sep 26, 2014 at 3:46 PM
CARADIODOC
  • 34,306 POSTS
This can't be diagnosed over a computer. The steering and suspension systems should have been inspected as part of the alignment procedure. In particular, worn control arm bushings will allow the alignment to change during braking and accelerating. An intermittent brake pull that occurs when the brakes get hot can be caused by rotors that are a different thickness. Also consider a tire pull. To identify that, switch the two front tires side-to-side. If that's the cause, the pull will be gone or go the other way.
Sep 26, 2014 at 3:53 PM
MATT07
you guys way better than yahoo.thank you very much and when comes to gullup survey i will give you guys a #10 stars.
Sep 26, 2014 at 9:38 PM
CARADIODOC
  • 34,306 POSTS
You're a wonderful human being! I can do even better when you give me more history, observations and clues to work with.
Sep 26, 2014 at 9:42 PM
MATT07
i will take your advice to change the two tires in the front and change side by side.and if the pulling change derection and if i still have the same problem.i willl take my car and have them check the control arms bushing.very helpul advice and again when counts to 1 to 10 .10 stars for you guys.THANK YOU.MABUHAY KAU.SALAMAT!
t
Sep 27, 2014 at 12:21 AM
