Pulling left when braking
2003 MERCEDES BENZ E320
180,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
ROCKITKY
Mechanic diagnosed bad lower ball joint left side. After replacement car now pulls left when braking.
Jul 20, 2018 at 5:47 PM
STEVE W.
  • 15,113 POSTS
What was it doing prior to the replacement? Was it pulling then? Does it only pull when braking? My first thought would be that the right hand caliper is not working properly and the left side is. Does it pull if you are driving straight and let go of the wheel? When were the brakes serviced last?
Jul 21, 2018 at 6:06 PM
ROCKITKY
Good brakes and calipers. Drives straight. Was wearing inside of tire diagnosed as bad lower left ball joint. Replaced it. Now, when braking, at any speed, pulls to the left.
Jul 22, 2018 at 3:13 PM
STEVE W.
  • 15,113 POSTS
Was the tire replaced as well? As it also aligned after the replacement?
Jul 22, 2018 at 3:44 PM
