Hello, it sounds like the drain hose for the Evaporator case is clogged up and it is not draining the condensation out. You said the AC compressor is coming on? but you have no cold air, so that might be the hot/cold blend door not moving. Under the vehicle, about where the dash is, you will see a small hose hanging down. Try to stick a piece of wire or something up to clear the passage way and see if any water drains out. With all the hvac actuator doors being in that case as well, they might have gotten wet and possibly blown a fuse. But see if you can clear the drain hose first and we'll go from there.,
Is this the Solara SE or SLE sub model?
And depending if you have Auto AC which monitors in-car and outside ambient temperature, or Manual AC which is more of a conventional setup, the wiring diagrams differ quite a bit.
The blend doors on most toyota's are on the driverside just above where the gas pedal is. The 2nd, 3rd and 4th diagrams below are of the blend door actuator if it ends up needing to be checked. but when you added Freon to the system is the AC compressor cycling off and on about every 8 seconds or so, or is it staying on all the time? And how did you add Freon, was the system completely emptied with an AC recovery machine or was it just added by the can?
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Apr 15, 2023 at 2:45 PM
