Pulley bolts keep coming off
1992 CADILLAC DEVILLE
171,000 MILES • 4.9L • V8 • 2WD • AUTOMATIC
OSEPHUS
  • 19 POSTS
Just changed my water pump ran the car for awhile seemed good no leaks, but the water pump pulley bolts keep coming off. could it be they are just old and I need new ones? thanks hope you had a great Thanksgiving.
Nov 29, 2019 at 4:24 AM
STEVE W.
  • 15,113 POSTS
It could be they are worn but I doubt it, more than likely the new pump has holes that are made slightly oversize. A way to stop them from coming loose is to use some Loctite type thread locking compound. Remove one bolt, clean out the hole with alcohol or brake parts cleaner to remove any oil or grease, then apply the locking compound and torque the bolt down to 115 inch pounds and then do the next one. Let it set up and they shouldn't come loose again.
Nov 29, 2019 at 4:50 AM
OSEPHUS
  • 19 POSTS
Thanks Steve, I’ll give it a try.
Nov 29, 2019 at 4:58 AM
STEVE W.
  • 15,113 POSTS
Most parts store will have a few varieties. Blue 243 should work for you. Buy the smallest you can find, it only takes a couple drops per bolt. Don't use Red unless you want to never remove them again, it takes heating with a torch to break that free.
You are welcome.
Please return anytime with your automotive questions.
Nov 29, 2019 at 10:19 AM
OSEPHUS
  • 19 POSTS
Hi Steve, I tried the locktite it lasted 2 days and the bolts came out again.
Dec 11, 2019 at 7:22 AM
STEVE W.
  • 15,113 POSTS
There has to be an issue with the holes in the pump flange then. When you put the bolts in are they tight or really loose? What brand is the replacement pump? Could you take a picture of the parts, maybe something will show up in those.
Dec 11, 2019 at 8:32 AM
OSEPHUS
  • 19 POSTS
Steve thanks for information. I went with the red loctite with new bolts seems to be working so far. I’ll let you know.
Dec 18, 2019 at 1:17 PM
STEVE W.
  • 15,113 POSTS
Are they going in with a tight fit or are they sloppy? The way they are installed they shouldn't even try to loosen as the torque on them is in shear not offset. Unless they were the wrong thread. What size wrench did you use?
Dec 18, 2019 at 7:49 PM
