2006 Proton Gen-2 Short Circuit during In-dash DVD Player i
2006 PROTON GEN-2
71,200 MILES • 4 CYL • FWD • MANUAL
ARZD
Need urgent help. During installation, i accidentally cut battery '+' wire and earth wire simultaneously. Upon complete, i found out that the door ajar lamp, the clock, alarm sys. and the DVD does not work. They only work when i brake.
I suspect that i burned some fuse, but i'd check all the fuse i can find, i.e. in the engine bay and under the dashboard (near to the accelerator pedal).
What actually happen.
Jan 5, 2010 at 2:13 AM
KHLOW2008
  • 41,814 POSTS
Hi arzd,
Thank you for the donation.
Our database do not have any wiring diagrams for your model so we are not able to indicate the fuse locations.
From the symptom descriptions, you definitely have blown a fuse. Did you use a test lampp to test every fuse?
If it is not a blown fuse, the other fault would be a bad ground connection. As the radio wire harness could not be grounded due to a poor connection, they are interlinked to the brake lights and when brakes are applied, the circuit is able to be grounded via the brake lights.
Jan 6, 2010 at 7:40 AM
ROCKERPALUZA
  • 11 POSTS
seems like a critical problem..is it dangerous to drive the car?
Apr 5, 2010 at 2:01 AM
