The above-listed lights have turned on. Also, the display that shows the odometer and the fuel gauge is just blank lit up white. Also, when i try to crank the vehicle, it hesitates to start, when i go to drive if it is in d (drive) it doesn't want to change gears, i have to put it in (low gear) when i first take off then i can shift it into d (drive) but it will not go above possibly third gear or into overdrive. When i plug in a code reader it was throwing up 1 code (crankshaft position sensor bank 1) i changed those sensors and it is still having the same issue. Do you have any advice on what i could do to fix the vehicle or does the Vehicle need a new transmission?
Mar 26, 2022 at 6:59 PM
