Codes P2094 and P0442
2015 CHEVROLET TRAVERSE
190,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
JOSELUISRAYMUNDO
  • 7 POSTS
Hi, i have these codes in my car:
P2094 B Camshaft Position Actuator Control Circuit Low Bank 2
P0442 Evaporative Emission System Leak Detected (Small Leak)
Could you tell me the name of the parts and the location?
The last time you helped me out with a sensor to the find the location and i did it exactly like you said.
Thank you
Mar 2, 2021 at 7:42 PM
The P2094 is for a bank 2 exhaust cam sensor. If you look at pic 1 below, it shows the location.
Here are the directions specific to your vehicle for replacement. The remaining pics correlate with the directions.
___________________________________________
2015 Chevy Truck Traverse FWD V6-3.6L
Camshaft position sensor replacement bank 2 (left side) exhaust
Removal Procedure
Remove the engine mount strut bracket. Refer to engine mount strut bracket replacement.
pic 2
Disconnect the engine wiring harness electrical connector (3) from the bank 2 exhaust camshaft position sensor (4).
Remove the CMP sensor bolt and sensor (4)
pic 3
Installation Procedure
Install the CMN sensor (4) and bolt.
pic 4
Tighten the bolt to 10Nm / 89 inch pounds
Connect the engine wiring harness connector.
pic 5
Install the engine mount strut bracket.
The P0442 indicates there is a small leak in the evaporative emissions system (EVAP). When they are small, what I recommend is to have the system smoke tested. A machine will pump smoke into the system at a very low pressure and the smoke will come out where the leak is located.
I recommend this because a small leak can be very difficult to locate.
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Mar 2, 2021 at 8:38 PM
JOSELUISRAYMUNDO
  • 7 POSTS
thanks for your time. and God bless you too.
Mar 2, 2021 at 9:09 PM
You are very welcome. Please feel free to come back in the future if you have questions. You are always welcome here.
Take care of yourself,
Mar 3, 2021 at 4:05 PM
JOSELUISRAYMUNDO
  • 7 POSTS
P2094 B Camshaft Position Actuator Control Circuit Low Bank 2 I already changed it as you told me and the same code continues to appear on my scanner, it will be defective or I have to run it. Yesterday I changed it and until now I have not run it, it will be because of that or it has nothing to do with that and in reality it is the sensor that was defective. What do you think? I would like to know your opinion.
Mar 12, 2021 at 6:52 PM
If you have a scan tool, clear the code. See if it comes back. If you don't have a scan tool, you will need may have to drive it for quite a few miles until the computer rechecks the circuit.
Let me know what happens.
Mar 12, 2021 at 6:55 PM
JOSELUISRAYMUNDO
  • 7 POSTS
I'm going to do it like that, of course I'll let you know. thank you again for your time.
Mar 12, 2021 at 7:04 PM
You are very welcome. I look forward to hearing back from you.
Mar 13, 2021 at 7:27 PM
