okay i am working on a friends car and well it is not engageing a gear and when it dose it pops in to gear.the customer said they were at a light and it died well i had toget it running .so i charged the battery before i got to see it myself after got it running i checked charging system to make sure it was working sense it had a dead battery .thisa was okay now i tryed to put it in to gear it did nothing at all an any gear i noticed a leak from trans so i checked fluid now this trans dosnt have a dip stick it has a fill hole on traansfer case i couldnt see one any where elses i checked in not running because the manual didnt say it needed to be running so i pulled the top plug and it was full fluid was a darker red ,i was wondering after i had looked at the mproblem online i found that this is a problem now i was wondering if it may be the shift silinoid that was causing the problem or something else i need to know if transmission is completly lost or if there is some other things i should cheak thnks for your time wes
Jun 14, 2013 at 6:38 PM
