Problem with transmission makes a wee sound?
2003 JAGUAR S-TYPE
67,000 MILES • V6 • 2WD • AUTOMATIC
AUSTINO
  • 220 POSTS
Good afternoon,
When ever time the transmission changes, it makes a wee sound, and this sound continues while driving. Also, whenever time the vehicle stops in the traffic and the vehicle wants to move again, sometimes the vehicle moves backward instead of going forward. As a result, in order for me to get the vehicle moving forward again, I have to switch the vehicle off and put it in park, then when I restart the vehicle, it will move forward again. In addition., sometimes the car revs and does not move while driving in traffic .Do you know what cause these problems? Can you tell me where the transmission oil can be refilled from? And how do you know when the transmission has in the correct amount of oil?
Thank you in advance for a speedy response.
May 2, 2024 at 4:46 PM
It sounds like the mode switch inside the shifter has gone bad, but we should run the codes to see if any are stored.
This guide can help:
Here are the transmission wiring diagrams so you can see how the system works, and I have included how to change or test the mode switch. Check out the images (below). Please upload pictures or videos in your response to any problems so we can see what to help you with.
May 3, 2024 at 12:35 PM
AUSTINO
  • 220 POSTS
Thank you. I will check and keep you updated on what I find.
May 3, 2024 at 5:27 PM
