Problem with the hose
1996 SUZUKI ESTEEM
15 MILES
SHREYAS
  • 16 POSTS
In the hose pipe do we need anything to block the half the amount of air?
If we do not the car does not start.
Please explain to me.
May 19, 2018 at 6:43 AM
Good afternoon.
What hose are you talking about?
Can you explain a little more of your problem?
May 19, 2018 at 8:28 AM
SHREYAS
  • 16 POSTS
I am talking about the air filter extension hose pipe.
I found a small thing that was placed to allow partial air move out and in.
May 19, 2018 at 9:00 AM
Okay, thanks.
There should be nothing in there to obstruct the flow of air into the engine.
Can you upload a picture for me of what you see?
May 19, 2018 at 9:01 AM
SHREYAS
  • 16 POSTS
If I do not block the half the portion of that the car does not start at all. And gives no pick up.
May 19, 2018 at 9:04 AM
SHREYAS
  • 16 POSTS
Right now I am helpless to send a picture.
But it is just made up of a tape kind.
May 19, 2018 at 9:06 AM
SHREYAS
  • 16 POSTS
The car has both LPG and petrol.
May 19, 2018 at 9:08 AM
Okay, looking for a picture from you.
Also, you need spark, fuel and compression for it to run. This must be verified to be sure these are in place.
May 19, 2018 at 9:09 AM
SHREYAS
  • 16 POSTS
I did not get you sorry!
May 19, 2018 at 9:15 AM
Which system are you using?
May 19, 2018 at 9:17 AM
SHREYAS
  • 16 POSTS
Spark, fuel, compression?
SHREYAS
  • 16 POSTS
System in the sense?
May 19, 2018 at 9:19 AM
Yes, the engine needs to be in good shape to run before getting it to run correctly. It is like going to the doctors and they check your weight, blood pressure and heart beats.
Are you using the gas side or the LPG side of the fuel?
May 19, 2018 at 9:22 AM
SHREYAS
  • 16 POSTS
The engine and things are fine. There was tear in the rubber part of the hose pipe. After replacement I am facing the problem. I am using the LPG and there is no problem in the gasket and filter.
May 19, 2018 at 9:27 AM
SHREYAS
  • 16 POSTS
This is the part which is causing problem I guess.
In between I found that thing.
May 19, 2018 at 9:32 AM
SHREYAS
  • 16 POSTS
If the air filter is bad will it give this results?
May 19, 2018 at 9:35 AM
Okay, thanks.
There is a mass air flow sensor on the end of the line. It measures the density of the air entering the system.
disconnect that and see if it starts.
May 19, 2018 at 9:36 AM
Yes, if the air filter is clogged, it will cause this issue. Check it for restriction.
May 19, 2018 at 9:38 AM
SHREYAS
  • 16 POSTS
What should I do exactly?
Only if I block half the pipe it starts.
But the next morning it gives the same result.
SHREYAS
  • 16 POSTS
It is not clogged, but a little old that is it.
May 19, 2018 at 9:40 AM
Do you have a scan tool to monitor the system? You need to see the pressure being delivered to the engine from the LPG system. Have you changed the filters for the system?
May 19, 2018 at 9:45 AM
SHREYAS
  • 16 POSTS
There is no problem.
The thing I feel is only the air intake.
That is where the problem lies.
May 19, 2018 at 9:49 AM
If you have low pressure to the engine, you will need to lower the amount of air. That is why you need to check the pressure. If you had sufficient pressure, you would not need to bend the hose in half.
You need something to check the pressure. You need a scan tool that can read it. You also need to check the filter for the gas as well.
May 19, 2018 at 9:54 AM
SHREYAS
  • 16 POSTS
Okay.
What can use to restrict the air intake?
Any material available on the automobile should?
Please suggest me one.
May 19, 2018 at 9:58 AM
I still need a picture of what you see. Please upload a picture for me.
May 19, 2018 at 10:15 AM
SHREYAS
  • 16 POSTS
Okay,
I will send you soon as possible.
May 19, 2018 at 10:16 AM
Sounds like a plan.
May 19, 2018 at 10:18 AM
