Low power
2006 VOLKSWAGEN PASSAT
250,000 MILES
AWAKEN
Hello, I have a problem with car listed above B6 2.0 TDI 140Hs with BMP engine.
The problem with the car is that it doesn't accelerate at low rpm's.
The acceleration is felt after 1,900 rpm.
What I've done so far:
Replacement of the camshaft with all the lifters, recycled repair kits for nozzles, recycling of 4 pcs.
Nozzles.
Removed EGR and DPF software and hardware.
No gaps on the turbo roads.
The inter-cooler is clean and in good condition.
The turbo was changed to a brand new one.
Removed all middle silencers(pots).
Also changed:
Flow-meter, MAP sensor, and N75 valve.
I've changed all the vacuums with silicone.
Changed the vacuum pump with another.
The VCDS doesn't show any mistakes - everything is in norms.
The car has changed oil and belts and the alignment is right
Changed software.CHIP TUNNING +30 hp. Still doesn't accelerate before 1900 rpm.
Despite everything I did, the car still doesn't work like it should be working.
I will be glad if someone can help me.
Thank you!
May 16, 2019 at 2:38 PM
It sounds like you still have blockage in the exhaust system. lets try disconnection the exhaust to see what happens. this guide should help:
May 18, 2019 at 11:36 AM
AWAKEN
I've tried it without exhaust, but I still have the problem.
May 18, 2019 at 12:36 PM
That only leaves low compression, low fuel pressure from the injector pump or the timing of the camshaft to crankshaft correlation is off. Have you run the codes?
This guide will help:
May 20, 2019 at 10:47 AM
AWAKEN
Sorry for the late answer, I had to check everything.
Everything is normal and there are no errors.
May 21, 2019 at 10:23 AM
Good compression and fuel pressure? how did you check it?
May 21, 2019 at 12:53 PM
