PROBLEM WITH LOST DRIVE POWER AFTER ENGINE WASH
2006 NISSAN SERENA
35,000 MILES
WARUGONGO
  • 4 POSTS
I own a Nissan Serana Rider S Autotech C25 2006 model. I took this car for engine wash then thereafter the car started jacking and lost drive power as drove back home. Allover a sudden the dashboard control light i.e "P" "R" "N" "D" "L" disappeared, i went back where the car was done engine wash and used pressure to blow off excessive water from control sensors. We switched on the engine the control lights came back but "D" light failed completely even after several trials.
At the moment the car gains drive power when i try to drive front and back the it shows "N" even when engaged to drive gear then it lost both drive and reverse power completely.
Now, i was advice by Mr. Roy to TAKE OFF BATTERY CABLE AND RE INSTALL TO RE BOOT SYSTEM the process i have done already but the problem still persisted.
Now, Could it be a problem with Gearbox Transmission Computer or the sensors if so which sensor could be a problem<
Please help.
Kind regard,
Francis.
Apr 19, 2013 at 2:00 AM
you have an electrical issue resulting from the engine wash.
water got into something electrical and is causing this codition. you need a shop to help you track it down as we cannot see it or touch it to go further
Aug 27, 2019 at 6:45 PM
