TRUCK DRIVES WITH NO PROBLEMS WHEN IN 2WD, WHEN 4WD IS SELECTED THE 4WD LIGHT COMES ON AND THE RFW LIGHT AS NORMAL BUT WHEN PUT IN GEAR AND YOU TRY TO DRIVE OFF THE FRONT END MAKES A HORRIBLE NOISE AS IF SOMETHING IS STICKING AND THE TRUCK DOESN'T MOVE NORMALLY.IF I PUT IT IN REVERSE IT SEEMS TO JAM UP AND WON'T MOVE. IF I SELECT 2WD AGAIN AND PUSH THE RFW BUTTON ON THE DASH THEN THE TRUCK WILL DRIVE OK
Apr 27, 2013 at 10:16 AM
