problem with doors
2002 TOYOTA HIGHLANDER
135,000 MILES • V6 • FWD • AUTOMATIC
SUYYETH POU
  • 12 POSTS
while braking in the car, there is sound clinking at passenger side at the pillar where seat belt located. the sound look like something touch at the body of the car or something door hinge problem.
Mar 13, 2017 at 7:44 PM
This is a common problem when the door switch goes out in the latch. With the key in the on position go to the door and try and wiggle it back and fourth to see if you can duplicate the noise letting you know the latch needs replacement.
Best, Ken
Mar 16, 2017 at 12:03 PM
SUYYETH POU
  • 12 POSTS
Thanks for your advice. I don't know what is the latch could u add me the picture. I just change door hinge but still hear clinking noise while braking. Any more idea ? Thanks u so much
Mar 24, 2017 at 2:30 AM
The door latch is what holds the door shut it connects to the striker in the door jam. Did you try pulling on the doors with the car running to see if you can duplicate the problem?
Best, Ken
Mar 24, 2017 at 10:47 AM
