cold/hot air blow only on one side
2000 LINCOLN LS
190,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
TKURYLO
  • 6 POSTS
Hi!
hot air blow only from driver side. But when I select MAX temperature, hot air blow on both sides (when I select MIN temperature, cold air on both sides). Sometimes, hot air blow from passenger side, and cold air blow from driver side (very rarely). Air blows separately on each side and do not mix. Diagnostic self-test of DATC - display no errors. Can you help me? Thanks.
Apr 15, 2018 at 6:34 AM
good morning.
Have you had the AC system checked? if the system is low in Freon or not functioning properly, this will be the result.
Also, the cooling system should also be checked to be sure as well.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
https://www.2carpros.com/articles/engine-cooling-system
Apr 15, 2018 at 7:03 AM
TKURYLO
  • 6 POSTS
"Have you had the AC system checked??" Yes. All is good with A/C.
Apr 15, 2018 at 8:28 AM
Okay, were the pressures checked and verified especially when the car is hot?
just trying to make sure the AC is not shutting down when warmed up.
Apr 15, 2018 at 8:31 AM
What are the pressures on the high and low sides?
May 2, 2018 at 1:27 PM
