Basically when you start the car the RPMs go up to 1,000, then after a 1 minute or 2 it goes down to around 860 RPMs which is normal RPMs, but during this 2 minutes if you press the gas pedal you can feel a misfire or a bit of rough idle which makes it difficult to get power from the engine, client a told me that the agency advise to change the IAC valve. Took the car checked the spark plugs which were okay, cleaned the throttle body and IAC valve nil fix. I also notice when you first start the car it won't hold idle it will just shut off, but after a second attempt it will start. Client also complained about getting low fuel mileage.
Will an IAC valve go bad without throwing a code? Any suggestions where i can start off? How to confirm if the IAC valve is the culprit? Would the IAC valve cause low fuel mileage?
I put the scanner there was no code found status was okay.
I have another client with the same issue but for her it's just the loss of power within the 2 minute period on cold start.
Apr 10, 2022 at 10:46 AM
