seems to glide as in not in gear when warmed up
1997 NISSAN PULSAR
341,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
DAVID EDWARDS2
Hi, my car is fine to drive until it warms up and then seems to glide as in not in gear and will suddenly catch on again and drive a bit more. The longer it is driven the worse it gets unless it is driven under eighty with no stops at all. Clutch has been replaced as I thought that was the problem as have leads. Any help would be appreciated. Thanks.
Apr 24, 2017 at 1:50 AM
KHLOW2008
  • 41,814 POSTS
For manual transmissions the only plausible explanation would be insufficient free travel of the master pump push rod. Whe this occurs, the clutch would self apply once the fluid heats up. Have the pedal push rod adjustment checked.
Apr 24, 2017 at 2:46 AM
