Hello ALLISON BROCKMAN,
Manual mode on an Automatic transmission relies on the driver and gives them control of when it shifts but regular Automatic mode relies on the computer to make the decisions for the best emissions, fuel economy and drivability.
However, a computer is only as good as its program. So, if the input data is wrong or it thinks it is something it is not then the engine computer will respond in the wrong way. Like incorrectly calculating load. If the computer cannot calculate how hard the engine is working, or load, it will respond with things like delayed shifting, performance issues, excessive fuel consumption or just be in the wrong gear. Making the transmission work harder.
To me, if I found that cracked boot on a customer's car, I would recommend replacing it. If your mechanic thinks it isn't going to cause a problem, I think he is wrong. Is it causing our specific problem? It is hard to tell.
Issues with vehicles can be complex and a lot of different issues have similar possibilities. Especially as they age and gain mileage, you can have multiple issues all leading to one or 2 main symptoms the customer is now noticing.
However, if there is an issue with the intake the engine will not perform correctly. Since the transmission uses a lot of the same inputs the engine does, engine problem can cause a transmission problem.
I mean it is a pretty big crack on the intake that goes right into the engine, so I find it hard to believe it isn't at least contributing to the issue.
It is possible it is burning oil or has a leak somewhere. I am sure you know this but just make sure you check it on level ground.
1) Start the engine, run for about 20 seconds or so and turn it off. (This will push the oil into the motor and filter)
2) With the engine off, remove the oil dipstick and wipe with a rag, stick the dipstick back in all the way and pull it back out. (The reason for this is when the engine runs, the oil will be thrown around the engine for lack of a better term and give a false reading. By taking it out and wiping it off first, this will give you a more accurate reading.)
I would check it every day before driving and keep a log of it. That way we can see if and how fast the level is dropping. Which will give us some insight into where it might be going, if it is at all.
If the engine is indeed losing oil, then it will cause the motor to be sluggish. However, as mentioned before, a lot of different things can cause it as well.
Does the issue get better after the low oil is found and oil is added?
Are the issues better or worse when the engine is hot or cold?
We have to use the process of testing and eliminating certain areas that could cause this issue.
It is possible it has a transmission problem but the gears that are used are the same in manual or automatic mode, the difference is the inputs. Usually, manual drivers will rev the engine higher than when in automatic mode. If there was an air intake leak it would be less noticeable if I am hitting the gas harder because the air coming in through the intake matches the fuel the engine computer is allowing more precisely. Under a light load like cruising around 40 MPH, I am going to hit the gas a little and let off and try to maintain my speed, so an air leak will have a more of an effect then because the airflow and fuel need to be more precise especially if I start going uphill.
However, let's try this. *For safety this should be done with a fire extinguisher handy and the engine cold. This can cause a fire so please be careful*
You will need some carb cleaner. This can be found at your local auto parts store. (I will add an image for you). Brake Cleaner will work as well but will damage painted surfaces and plastic.
1) With the engine in park and idling, spray some carb cleaner in the area of that cracked coupler with everything for the intake attached the way it should be. Use the straw that came with it so you can be more precise and use short sprays.
2) Now you are going to spray around that area of that cracked boot and if it is a big enough leak, you will hear the engine RPM rise slightly.
The boot needs replacement regardless but let's see how much of an impact it is having on the engine.
Here is a video on how to do this. Let me know if you have any questions.
https://youtu.be/9CPqbaSgcok
Then we will do this same test on other areas to make sure there are no vacuum leaks anywhere else.
Let me know what you come up with or if you need any guidance. I am here to help.
There are a lot of things that can cause these issues, but condemning the transmission or engine itself I think is a little premature until we have more data. These things are possible, but I find looking at more likely issues first is best so at the very least we can eliminate them. Plus, it only has 150,000 miles on it.
Also, it is possible to have a small enough vacuum leak that this test may not work on, so trying the same spot a couple times is best to be sure. It is possible to have several small vacuum leaks at the same time as well.
So, if you could do this test found in the video above and let me know your results, we will begin the process of elimination.
Thank you,
Brendon
Aug 21, 2023 at 3:42 PM
