I'm trying to replace my water pump, but the problem is that on the 2016 model the engine is too close to the frame that electric water pump is not able to get out. Someone mentioned to me that we need to lower the engine a bit to give enough room to replace the part. Seems right because I don't see any other way without moving the engine a bit to get the part out.
What do you guys think? Is that correct or is there another way to replace the water pump?
Nov 29, 2022 at 6:44 PM
