How much would it cost to put a new camshaft?
2002 CHEVROLET TAHOE
200,000 MILES • 5.3L • V8 • 2WD • MANUAL
TJ BARON
How much would it cost to put a new cam shaft in my vehicle listed above 5.3 and 4.8 engines?
Oct 23, 2024 at 10:44 AM
TJ BARON
Also wanted to know the cost to make it have 500hp. Parts/Labor.
Oct 23, 2024 at 10:50 AM
This video series can help you build the 500 hp engine and what the cost would be.
https://www.youtube.com/watch?v=NyX6FwLYDuc&list=PLe3kz1i_LrtX5402mzO6ovoz8xeUdwZ8B&pp=iAQB
Just to install a new camshaft the labor is
Camshaft, Engine 15.8 HRS@ shop rate
and the OEM camshaft would be
Camshaft 12560967 $740.85
there will be gaskets and oil, filter and coolant as well so add a little more and you should be close. Also, they will want to replace the lifters as well
Valve Lifter 17122490 $57.50 x 16 = $920.00
Let us know if you need anything else.
Oct 23, 2024 at 12:09 PM
