I had asked about the locations of bolts diagram. I needed to replace the Clutch, Clutch disc, turn the Flywheel, Pressure plate, Slave cylinder, Master clutch cylinder, I had three bolts left didn't remember where they went since there's threaded holes throughout the block and transmission area. There was one particular bolt not a 10mm but same design but smaller a 7mm or 8mm and the top portion of the bolt is threaded the remaining portion is smooth.
Nov 26, 2021 at 6:18 PM
