Mot failure on welding
1996 TOYOTA PREVIA
78,000 MILES • 2.2L • TURBO • 4WD • AUTOMATIC
DENNY280711
Mot failure on welding 2.4.a3 suspension component mounting excess corrosion.
Nov 16, 2018 at 12:22 PM
JONNYB1963
  • 263 POSTS
That happened to my brother-in-law over there. He failed MOT and took it to a local shop to have it re-welded. Its cost him about 350 pounds I believe.
I am not sure how adept you are at welding but if you are, then you need to identify the component and weld that caused you to fail MOT and then grind, clean and re-weld the part in question. Afterwards a good coat of primer and paint to keep this from happening again.
Regards
Jon
Nov 16, 2018 at 1:01 PM
DENNY280711
Thank you I would scrap it it is an old bus, but I have put a lot of money into it and decked all the back out. I will try and find a welder as I am useless with things like that. I would pay 350.
Nov 16, 2018 at 1:03 PM
JONNYB1963
  • 263 POSTS
Very well. Good luck in finding a welder to do the work.
Afterwards though you can handle the painting yourself if you are so inclined!
Best of luck,
Jon
Nov 16, 2018 at 1:06 PM
DENNY280711
Yes, I can manage that.
Nov 16, 2018 at 1:08 PM
JONNYB1963
  • 263 POSTS
Awesome. Best of luck!
Jon
Nov 19, 2018 at 8:42 AM
