When pressing accelerator more than half way engine cuts out
1987 NISSAN STANZA
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
BLOWN-FLAT
  • 5 POSTS
If I lightly press the gas pedal car runs great but if I press it more than half way on the pedal it totally cuts out like its not getting fuel or spark. I recently did replace the fuel pump with new OEM one so not that. It will gradually only speed up to freeway speeds just can't mash gas pedal much.Was thinking might me throttle position sensor.It's fuel injection.
Also is there a way to read codes on this old a car?
Jan 14, 2020 at 4:00 AM
It does sound like you don't have enough fuel pressure. Have you confirmed that it is within spec? Was the fuel filter replaced at the same time as the pump?
As far as pulling codes, take a look through this link and see if it helps.
https://www.2carpros.com/articles/nissan-obd1-diagnostic-trouble-codes-and-retrieval-procedure-1984-to-1994
Let me know if that helps.
Jan 14, 2020 at 8:28 PM
BLOWN-FLAT
  • 5 POSTS
Yes fuel filter is brand new. I'll check the pressure.
Jan 14, 2020 at 11:53 PM
Check the fuel pressure and let me know what you find. Let's hope it is a simple fix.
Jan 16, 2020 at 3:52 PM
BLOWN-FLAT
  • 5 POSTS
Thanks Joe. I will soon with my new fuel pressure testing kit and let you know.
Greatly appreciate your help. I'm also wondering if maybe I got some water in somewhere when I went to the quarter car was and did the motor. I know not to get the distributor and coils wet so I always wrap them up.
With thanks,
Ron
Jan 16, 2020 at 6:02 PM
Anything is possible. Let's hope it isn't something electrical because that can become a headache. LOL Let me know about the fuel pressure.
Jan 16, 2020 at 6:13 PM
BLOWN-FLAT
  • 5 POSTS
Okay, will do.
Ron
Jan 16, 2020 at 6:16 PM
Hi Ron,
Any luck with getting the fuel pressure readings?
Jan 19, 2020 at 9:05 PM
BLOWN-FLAT
  • 5 POSTS
Thanks for asking I'll get to it this week.
Ron
Jan 19, 2020 at 10:08 PM
Sounds good.
Jan 20, 2020 at 7:32 PM
