Power train control module
1996 DODGE INTREPID
143,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
BREEZY WARREN
  • 4 POSTS
How do you find a replace this item for this year?
May 11, 2018 at 11:15 AM
CARADIODOC
  • 34,306 POSTS
Easiest and least expensive is to find a used one from a salvage yard.
What kind of problem are you trying to solve?
May 11, 2018 at 11:59 AM
BREEZY WARREN
  • 4 POSTS
I know where to purchase this. I need a diagram to locate it on the car.
May 11, 2018 at 12:51 PM
It looks like the PCM is located under the air box here is a diagram to show you (below).
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
May 11, 2018 at 12:53 PM
BREEZY WARREN
  • 4 POSTS
I do not have one there! I already check.
May 11, 2018 at 1:06 PM
BREEZY WARREN
  • 4 POSTS
Here is the image of my intake:
May 11, 2018 at 1:25 PM
BREEZY WARREN
  • 4 POSTS
This another one.
May 11, 2018 at 1:26 PM
CARADIODOC
  • 34,306 POSTS
For years, Chrysler put their engine computers on the left side, (driver's side), on the inner fender, beside the battery. By the 1997 model year, they were on the right side, as shown in the drawing, on Intrepid's and Concorde's. You might have a mid-year model that was built as a 1995 or a 1997, so check both places. We had a 1994 Intrepid that was used to test a new assembly line, then Chrysler donated it to my community college. That one had the computer on the driver's side. I built a lot of electrical "bugs" into that car and I was very familiar with it. Some parts of that car were built as a 1995 model.
May 11, 2018 at 5:39 PM
BREEZY WARREN
  • 4 POSTS
Well I talk someone today they said the PCM was under the airbag and the ECM is by the battery on the right side by the fuse box.
May 13, 2018 at 10:34 AM
Did you remove the air cleaner housing it is under that.
May 13, 2018 at 10:48 AM
