Power-train light turned on
2016 JEEP LIBERTY RENEGADE
30,400 MILES • 4.0L
MSSARAI985
But it is running okay and I am out of town. can i keep going?
Feb 20, 2020 at 6:42 PM
It is hard to know without knowing what the code is that goes with it. I would suggest just stopping by a parts store like PepBoys, Autozone, or a similar one and ask them to pull the codes. Get me the codes and we can figure out what the possible causes are and that will tell us the severity.
Feb 20, 2020 at 6:51 PM
MSSARAI985
does PIDB700 mean anything?
Feb 20, 2020 at 7:07 PM
Unfortunately it does not. Where did that come from? With a check engine light you will get a code that is something like Pxxxx. A P followed by 4 numbers.
Feb 20, 2020 at 7:38 PM
JIS001
  • 3,412 POSTS
If the check engine light is flashing then you should not drive since you will melt the catalytic converter. Something like an evap code then you should be good. But as KASEKENNY1 pointed out, if you can post the trouble codes we will be able to guide you from there.
Feb 20, 2020 at 7:43 PM
