I just installed 2006 Mazda 2.0 engine into my 2007 Mazda 3i 2.0.
I replaced rack and pinion and bled the system and installed a filter in the line in case there was anything foreign in then existing system, I started the car it fired up immediately and the yellow steering wheel light came on, I added more fluid ad I continued bleeding the system , I had the cap off and turned wheel partial one way to other way as the manual specified. I've tried PILKINGTON fuse and negative terminals to reset the computer, I pulled both sides off battery ,hit the brake pedal 5 times and waited 15 minutes as another person had done in the past but I got nothing. my power steering doesn't want to work until your moving, turning around there is no assist. if you have any answers that will help I greatly appreciate it.
Jun 15, 2020 at 1:30 PM
