Power windows stopped working. I went to fuse panel- roadside dash side plate-and the 10 amp fuse was blown. Tried 15 amp-blown, 20 amp-blown and then 25 amp the windows the windows worked fine but the fuse got so hot I pulled it. What could cause this? Also, the 15 an 20 amp fuses blew before I could put key in ignition.
Thank you in advance.
Mar 27, 2018 at 7:00 AM
