Power windows not working
1996 HONDA CIVIC
175,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
AARON LISTER
  • 5 POSTS
Need some help. My power windows do not work at all. I light tested all fuses and the relay. And even the main switch. Lights up when I push every button except for the passenger window button. Could this somehow cause none of them to work? Also, when I push the driver button with the light tester grounding the switch (think the ground wire is out by the way. I had the light tester stuck in the ground wire in the harness), it makes a buzzing noise. I am at a loss here.
P.S. My mirrors and locks do notwork either. Not sure if that is related.
Dec 12, 2016 at 3:07 PM
HMAC300
  • 48,601 POSTS
check all the fuses in picture along with relay. it may be a window control unit in master switch however.
Dec 12, 2016 at 3:46 PM
