I am assuming it is the driver window but no matter which window it is we need to access the window motor and check for voltage to see if it is getting power. If it is then the motor is the issue. If not, then we have a switch, fuse or wiring issue.
https://www.2carpros.com/articles/door-panel-removal
Let's start with this and go from there.
Oct 25, 2020 at 4:41 PM
