Driver's side power window not working properly
2002 FORD EXPLORER SPORT TRAC
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
My drivers side power window is stuck 1/3 of the way down. I need to fix this problem to repair a broken door handle on the same side and door.
I wanted to start with the fuses, however, all the other windows work (front passenger side is sluggish to start). I was wondering if the window motors had separate fuses, or if they were on one fuse.
If it is not the fuse, I need to get the window up either manually, or jump at the switch, but not sure how to do that. need some guidance.
Feb 4, 2019 at 6:13 PM
It sounds like the window motor went out because the system runs off one fuse. but to be sure here is a guide to walk you through the tests with diagrams below to show you how to replace the window motor/regulator:
https://www.2carpros.com/articles/electric-window-repair
This guide walks you through the steps on a similar car check the diagrams below for yours:
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
You can get the part from Amazon or Rockauto. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Feb 6, 2019 at 2:07 PM
