Power windows
2002 LINCOLN TOWN CAR
64,000 MILES • 4.8L • V8 • 2WD
ROCCO DAGGS
  • 12 POSTS
Drivers window will not operate until the temperature go to about 70 degrees or lower. Will not work all summer. Once the fall comes it will work all winter and spring until it gets hot out. It has been like this for two years now. I replaced the switch in the door. Any ideas? Also had a Chevrolet Cavalier with same problem. Thank you
Sep 15, 2016 at 3:57 AM
HMAC300
  • 48,601 POSTS
it is probably the window module bad, or wet it gets hot and wont work have it checked by scanning for codes by a mechanic.
Sep 15, 2016 at 6:20 AM
