More than likely this is a master window switch issue but it could also be a ground issue as both these systems share the G302 ground.
However, if the door locks are working then the ground is most likely fine as it shares this ground as well.
What I would do is check the voltage coming out of the switch when opening or closing the window so that we can see if there is voltage.
As you can see the passenger switch runs out of the master so if the master is not working then both stop working.
Please let us know what questions you have and we can go from there. Thanks
May 11, 2021 at 3:55 PM
