Power window switch drivers side not working
2007 BUICK LUCERNE
146,000 MILES
TIM BURK
All other switches work on power switch but drivers window does not work.
May 12, 2018 at 10:55 AM
Good afternoon.
The first thing you need to do is to check for power to the switch. I will attach a wiring diagram for you to view for the wiring to test.
Check the red/white tracer for power to the switch.
You need to pop up the switch from the panel and test with a voltmeter or test light.
May 12, 2018 at 11:36 AM
TIM BURK
The switch is now working, the connections were loose. Thank you very much!
May 12, 2018 at 2:13 PM
Good find. Glad it works.
May 12, 2018 at 3:20 PM
