Are you trying just the master switch? If so, try each door switch. If they work with the individual door switch, check the master switch.
Check switches for power with a voltmeter while working the switch. I would be surprised if all door motors went out at the same time.
If they don't work with any switch, and you have already checked relays and fuses, there might be a ground problem. I believe the ground for the power windows is on the drivers side behind the plastic panel next to the emergency brake. Make sure it is not broken or corroded.
Oct 14, 2020 at 12:53 PM
(Merged)
