Power window master switch
2003 HONDA ACCORD
210,000 MILES • 2.6L • V6 • RWD • AUTOMATIC
RAPSTER62
Just replaced the master power window switch on my drivers side with a second hand unit. The external mirror control works, but the power window switches and central lock do not. Do I have to program the new unit in?
Aug 15, 2017 at 4:58 AM
No the switch should just work. Was the part number the same on both switches?
Please let us know.
Aug 16, 2017 at 2:10 PM
RAPSTER62
HI Ken, did not check the part number but sent the part back. Thanks for replying.
Aug 16, 2017 at 6:54 PM
Aug 16, 2017 at 9:14 PM
RAPSTER62
Hi Ken, got to try a used part at a wreckers the other day and it worked straight off the bat. Unfortunately not so fir the drivers window. Looks like either the wiring or the motor itself. Any suggestions as to how to diagnose which is at fault?
Aug 20, 2017 at 6:35 PM
CARADIODOC
  • 34,306 POSTS
The wiring between the door hinges is okay if the passenger windows work from the driver's switch assembly. For the driver's window, the easiest way to test it is to test for voltage right at the motor connector. To be accurate, that testing should be done with the motor plugged in. If that is difficult to do, you can measure the voltages with the motor unplugged, as long as you understand if 0 volts shows up when it should be 12 volts, there's a switch or wiring problem, but if 12 volts shows up when it's supposed to, we have to get a little more involved with additional testing to be sure we found the right voltage.
If you can't get to the motor easily, back-probe the red / yellow and red / black wires right at the switch connector, (one meter probe in each wire at the same time). You should find 12 volts when you activate the switch one way, and minus 12 volts when you switch it the other way. If you have that, suspect the motor.
Another clue is to listen for any noise the motor makes when you activate the switch. If you hear a little groaning or crunching noise, the regulator likely uses a system of cables and plastic pulleys, and the cable is coming apart.
Aug 20, 2017 at 10:57 PM
