Power window failure
2013 HYUNDAI TUCSON
33,000 MILES
ALEXANDER SINDER
Today all 4 windows and all switches are not working all of a sudden.
Jul 17, 2020 at 7:45 PM
If power was lost to all windows, it sounds like the power window relay has failed. It could be a fuse as well. Take a look at the attached picture I attached. That is the instrument cluster fuse box. I need you to check the two fuses I circled. Also, remove the relay and switch it with another one that has the same part number to see if it makes a difference.
If you look at pic 2, I included a pic of the instrument panel fuse box and highlighted the components needing checked.
Here are a couple links you may find helpful:
Let me know what you find.
Jul 17, 2020 at 7:56 PM
