Hello again,
The drivers side switch is the master switch for both the power door locks and the power windows, but it does not have to be installed for the passenger side power door locks and windows to work. In the diagrams down below I have also included the power door locks wiring diagram for your vehicle. If you notice in the power windows wiring diagram, that was sent to you previously, and the power door locks wiring diagram, following the circuit from the circuit breaker on top on down, the split for the passenger door's electrical feed happens before the master switch. This means it is a parallel circuit, and Ohm's law states that each leg of a parallel circuit must have source voltage, so your passenger door must be getting battery voltage. Please get back to us with what you find out.
Thanks,
Alex
2CarPros
Jul 29, 2019 at 2:45 PM
