It is possible for the switch to be bad or have a loose connection.
First you want to make sure that it is the button and not a wiring issue.
You will need to check to see if there is power to the switch.
Here is a helpful guide on how to test the window switch:
https://www.2carpros.com/articles/electric-window-repair
I have attached diagrams showing how to test the switch for your reference.
Thank you.
Mar 18, 2022 at 10:15 PM
