Passenger side power window will go down but not up using either the driver's master switch or the passenger switch. Window will go up and down if I connect the motor directly to the battery. Replaced the passenger door switch with new one. Still won't go up with the new switch.
If motor and switch are both good, what else could cause the window to go down but not up?
Aug 23, 2020 at 12:46 PM
