Power steering system not working?
2005 HONDA ACCORD
119,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RICKMAPES1
  • 5 POSTS
No power steering. Rebuilt the pump, no change. Replaced the pump with a new unit, no change. Replaced the rack with a new unit, no change. Replaced the high-pressure line, no change. No leaks in the system. Always keeping an eye on the fluid level throughout every procedure. Any suggestions?
Oct 13, 2023 at 7:47 AM
When the engine is running, can you remove the fluid cap for the power steering and see the fluid circulating? The only thing left to the system is the return hose. You may have a defective steering rack. Here is the steering system diagram so you can see what I am talking about. Also, here is a power steering system flush video which you can use to see if the pump is working.
https://youtu.be/iu0_YkCkL40?si=CL37VR3whZv7qNyC
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Oct 13, 2023 at 9:31 AM
RICKMAPES1
  • 5 POSTS
Friday, I removed the return line from the reservoir and capped off the return line port on the reservoir. I connected some clear tubing to the return line and put it in the top of the reservoir. With the tires off the ground, I cranked the wheel from lock to lock several times. The fluid was flowing, and I saw several air bubbles come up. Next, I started the engine and could see that the fluid was flowing well, and more air bubbles came up. I was encouraged, but when I put it all back together and made sure the fluid level was good, I lowered the car and there was no change. The power assist seems to work a little, but it's mostly not there. Your thoughts?
Oct 16, 2023 at 7:12 AM
Since you did two pumps, and you can see fluid flowing, I would say you have a defective steering rack.
Oct 16, 2023 at 9:49 AM
RICKMAPES1
  • 5 POSTS
Bummer, but I'm afraid you are right. The first time wasn't fun, but I can try again.
Oct 16, 2023 at 10:30 AM
Yep, I hear you, but it happens. Please let me know how it goes.
Oct 17, 2023 at 9:08 AM
RICKMAPES1
  • 5 POSTS
Will do. Fortunately, the vendor on Amazon is sending a replacement no charge. Thanks again.
Oct 17, 2023 at 1:29 PM
RICKMAPES1
  • 5 POSTS
Finally got the replacement installed last night. It was an improvement. i think there must be some air in the system that will work out with time. With the car jacked up I turned the wheel from stop to stop 10 times until the gurgling stopped, but after that there was still some stiffness (more than normal) at low speed turning. I'm thinking you get what you pay for. The vendor was the lowest price on Amazon.
Oct 26, 2023 at 9:43 AM
Yep, we always installed reliable parts for this reason. Glad you got it fixed. Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Oct 26, 2023 at 12:18 PM
