If the pump is the only part that is bad, you shouldn't need anything else except power steering fluid. Since the serpentine belt will be off to remove the pump, confirm it is in good condition because now will be the time to replace it if needed.
Here are the directions for pump replacement. The attached pictures correlate with the directions.
___________________________________________
POWER STEERING PUMP REPLACEMENT
Power Steering Pump-Replacement
Removal Procedure
1. Remove the radiator air intake baffle.
2. Remove the air cleaner assembly.
See Pic 1
3. Remove the drive belt.
4. Install a drain pan under the vehicle.
5. Disconnect the power steering pressure hose (1) from the power steering pump.
6. Disconnect the power steering cooler hose (2) from the power steering pump.
7. Disconnect the wiring harness from the wiring loom on the power steering pump.
See Pic 2
8. Remove the power steering pump mounting bolts.
9. Remove the power steering pump.
10. Remove the power steering pump pulley.
Installation Procedure
1. Install the power steering pump pulley.
Notice: Refer to Fastener Notice in Service Precautions.
See Pic 3
2. Install the power steering pump.
3. Install the power steering pump mounting bolts.
Tighten the power steering pump mounting bolts to 25 Nm (18 ft. lbs.).
See Pic 4
4. Install the power steering cooler hose (2) to the power steering pump.
5. Install the power steering pressure hose (1) to the power steering pump.
Tighten the power steering pressure hose to 25 Nm (18 ft. lbs.).
6. Remove the drain pan from under the vehicle.
7. Install me drive belt.
8. Install the air cleaner assembly.
9. Install the radiator air intake baffle.
10. Bleed the power steering system.
11. Inspect the power steering system for leaks and the hoses for clearance away from the frame and other components.
Jan 12, 2019 at 2:34 PM
