That pump is a tight fit. First you need to remove the air cleaner housing, then the drive belt. Now unbolt the high-pressure hose from the pump.
Now you need to get under the car and remove the low-pressure hose to the Power Steering pump. With it off you unbolt the A/C compressor so you can move it aside, you don't need to disconnect the lines just unbolt it for access. Then remove the two lower Power Steering pump bolts. Now move back topside. Disconnect the A/C wiring harness for more room. Then unbolt the coolant tube and move it out of the way, now you can access the two upper Power Steering pump bolts. Remove those and you can remove the pump. Bolt sizes will vary with each application. A common metric set should handle the job though.
Jan 31, 2023 at 8:35 PM
