Power steering pump comparison
1999 OLDSMOBILE ALERO
100,000 MILES • 3.4L
DEANGELOSMITH
  • 20 POSTS
I use a 2003 Alero for parts. The power steering pump in my car has a bad leak coming from the area where the switch is plugged in on the front. I want to swap it with the pump in the 2003 Alero but upon my inspection they look to shape the same but the 2003 Alero's pump does not have a place to plug in on the front like the pump in the 2003 Alero. I am a little skeptical as if it would work? Both are 3.4L engines.
Sep 12, 2016 at 5:21 PM
SATURNTECH9
  • 30,869 POSTS
There compatible as far as the pump goes except it is the wrong pump. since there are two pumps one with evo and one without evo steering .
Sep 12, 2016 at 8:26 PM
