You need to either get it from under the car or you will need to remove some items at the top and have very small hands.
I would suggest getting it from the bottom.It becomes accessible if you loosen the cradle (Sub-Frame) bolts and slightly lower the rear of the cradle to get access
Image (Click to enlarge)
Mar 3, 2019 at 9:49 AM
SYLIS
MEMBER
1998 Chevrelot Cavalier.
Trying to replace the power Steering pressure hose, but I can't see how I get to the lower fitting in order to remove it, how do I access the lower end of the high pressure line in order to replace it.
Mar 4, 2019 at 6:30 PM
(Merged)
CERTIFIED EXPERT
you can acess it from the bottom. it is easier for us due to a lift. at home, it becomes more difficult. use a 18mm crow foot to loosen.
(Merged)
SYLIS
MEMBER
Well, I put the car on ramps, it still doesn't appear to be easy to get to, though maybe I am not looking at the right line. I'll see if I can take a picture and maybe you could show me how I get the crows foot in there.
(Merged)
CODYJONES08
MEMBER
i can not figure out how to remove the high pressure power steering line from the steering box. ive tried a crows foot, open end wrench, but nothing seems to work. please help me remove the high pressure power steering line from the steering box.
(Merged)
HMAC300
CERTIFIED EXPERT
it's pretty much cut and dried, especially with a line wrench are you turning it counter clockwise? that is the way it should go. Don' tknow what else to tell you
(Merged)
CODYJONES08
MEMBER
yes i turned the wing nut counter clock wise, i figured out how to remove the line thanks guys. I had to remove the fuel sensor located near the air intake and then i was able to slide a crows foot with a long extension onto the wing nut and remove it that way.
(Merged)
BEAUTIFUL011711
MEMBER
1 POST
i have no clue where to start
(Merged)
CERTIFIED EXPERT
Remove the lines after installing new ones make sure you bleed the power steering pump
(Merged)
RHONDAX09
MEMBER
1 POST
how to replace power steering hose on a 96 chevy cavalier
(Merged)
CERTIFIED EXPERT
Removal/Installation
Disconnect battery ground cable to begin then raise the car up on jack stands. You will need to remove the pump is you cant get to the lines. Then use a line wrench and have a fluid catch can ready because fluid will leak out. Make sure you match the new lines to the old ones. When reassembled refill with fluid and you are all set, you might need to recheck the fluid level.
