power steering not working?
2004 TOYOTA HIGHLANDER
138,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ASH SIMMONS
power steering went out on the vehicle listed above. I had replaced the rack and pinion, and the pump and the steering is still really hard.
Jul 11, 2023 at 10:24 PM
It takes a day or two for the fluid to dissipate the air from the hydraulic system. I would start the engine and then move the steering lock to lock and then shut the engine off and recheck the fluid level. Also, when the engine is running you should hear the pump labor when the steering wheel is moved, if not you may have a defective pump. Also please check out this guide:
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jul 13, 2023 at 10:56 AM
