The car listed above is a 328i. Power steering sound, squeaky, whining noise when turning. The reservoir and hoses have been replaced, there is no leak seen, no loss in power steering fluid. The car did not have power steering fluid for some time when there was a leak could this have damaged the pump.
Can the pump still be bad even if there are no leaks from the reservoir and hoses and no loss of fluid? I thought if the pump was bad then there would be issues when turning the wheel, would feel heavier but that is not the case. Steering seems fine. Only issue is the sound when turning.
Apr 14, 2023 at 7:45 PM
