What are the exact places of power steering lines on reservoir? I cannot fix unless i know if its the return or high pressure line.
Mar 21, 2017 at 5:30 PM
CARADIODOC
CERTIFIED EXPERT
Not sure what you are trying to fix or what you are asking? Are you trying to identify a line that is leaking? If so, that is not likely to be the return line with no pressure in it. The return line is rubber where it connects to the reservoir, and is held on with a small band clamp. The pressure hose is metal where it bolts to the pump housing.
Mar 21, 2017 at 5:41 PM
HWB3648
MEMBER
Thank you thats all i needed to know.
Mar 21, 2017 at 5:42 PM
CARADIODOC
CERTIFIED EXPERT
Thank you so much for using our site! If you have any other questions do not hesitate to ask!
