power steering leaking
1992 CHEVROLET TRUCK
190,000 MILES • 3.5L • V8 • 2WD • AUTOMATIC
CHRISTY GRILLO LUNDGREN
Power steering is not working properly. Having to replace fluid regularly.
Aug 17, 2017 at 9:47 AM
We need to see where the leak is coming from. Fill the system without spilling any fluid. Then use a flashlight to see if you can tell where it is leaking. If needed start the engine and have someone turn the wheel back and forth which will make the fluid leak. Here are some popular guides to help you get the problem fixed once you see what the problem is.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
and
https://youtu.be/KKeFqHLuRQ0
and
https://youtu.be/BGBUv5r9fk0
Aug 17, 2017 at 4:24 PM
