Here you go follow these procedures and you should be okay.
Power steering fluid reservoir to power steering pump supply hose.
Removal:
Open engine compartment and fit paintwork protection covers.
Place a drain pan under the pump.
Disconnect hose from pump.
Release clip (1).
Disconnect hose and allow it to drain (2).
Fit blanking plugs to pump and hose.
Disconnect hose from reservoir.
Release clip (1).
Disconnect hose (2).
Fit blanking plugs to reservoir stub pipe and hose.
Remove clips from hose.
Remove drain pan and discard fluid.
Installation:
Installation is reverse of removal procedure.
Refill with new fluid and bleed air from the system. Refer to power steering system filling and bleeding .
Power steering pump to steering gear pressure line.
Removal:
Raise vehicle on a four-post ramp.
Place a drain pan under steering rack.
Remove retaining straps which secure hose to steering rack.
Disconnect hose from steering rack.
Remove bolt from retaining plate (1).
Release hose, hold it clear of steering rack and allow fluid to drain (2).
Fit blanking plugs to hose and steering rack port (3).
From above the vehicle, disconnect hose from pump.
Release union nut (1).
Fit blanking plugs to hose and pump port (3).
From below the vehicle remove hose.
Remove hose (1).
Remove mounting rubbers from hose (2).
Installation:
Secure hose to track.
Locate hose and retaining plate (1).
Fit and tighten bolt (2).
Fit hose to pump.
Remove blanking plug from hose (1).
Fit a new O-ring seal to hose (2).
Remove blanking plug from pump (3).
Fit and tighten union nut (4).
Steering gear to fluid cooler return hose
Special Service Tools.
Removal:
Release hose (2), hold it clear of steering rack and allow fluid to drain.
Fit blanking plugs to hose and port (3).
Disconnect cooler to steering rack hose.
Release Quick Fit hose clip using special tool 310 - 044.
Disconnect hoses and remove tool.
Fit blanking plugs to both sections of hose.
Installation:
Tighten retaining plate bolt.
Fill with new fluid and bleed air from the system. Refer to power steering system filling and bleeding .
Fluid hoses
Item Description:
1. Return Hose.
2. High Pressure Hose.
If vacuum filling equipment is available, proceed as follows:
Disconnect both the high pressure hose (2) and return hose (1) from the PAS pump and the return hose from the steering rack.
Drain as much fluid as possible from the system by turning the steering from lock to lock two or three times.
Reconnect all hoses.
Fill the system using the vacuum equipment according to the manufacturers instructions.
Start the engine and top up the fluid as necessary.
Turn the steering from lock to lock two or three times with the engine running, topping up with fluid as necessary.
If possible, run the engine for twenty minutes to expel any remaining air.
Let me know if you need anything else.
Tom
Jul 28, 2020 at 1:12 PM
